It is currently Wed Jun 19, 2013 11:52 am
PostPosted: Tue May 29, 2012 1:35 am
When I do a import into Lightroom and was shooting JPEG/RAW, I only see the RAW files. For most of the time this is fine but sometimes the shoot may not have been important or I'm in a hurry. I have a shooting preference set on my JPEGs so there is some adjustments made during the save (sharping, saturation, contrast) That I'm pretty happy with. How do I get to them thru Lightroom. If I'm in a rush sometimes I just want to export them and get them on to a CD fast.
Mike "The Squirrel"
PostPosted: Tue May 29, 2012 2:13 am
Oh also, what about controlling how much zoom? I can click and get 100% and then back but I can't find anything in between :|
Mike "The Squirrel"
PostPosted: Tue May 29, 2012 4:20 am
OK, quick things first: do you have "Treat JPEGs next to RAWs as separate photos" checked in your Preferences (General tab)? If not, checking that will do what you want, but be aware that it will do this for every import (unless/until you uncheck it again). Personally, if it's only occasionally that you want both RAWs and JPEGs, I would copy them to separate folders on the hard drive first, and then Import (Add) from there. (Since the files are no longer "next to" each other, the above setting will not apply.)
There are two ways to control zoom level in the Library module:
The Navigator (in the upper left corner) has buttons for: Fit, Fill, 1:1 and a popup pick list (the two arrows) that goes from 1:4 to 11:1
And in Loupe view (single picture), there's a Zoom slider on the toolbar beneath the image. (If it's not there, click the down arrow on the right end of the toolbar and check "Zoom".)
PostPosted: Fri Jun 01, 2012 1:48 am
In Lr4, there is a "navigator" in the upper left corner. To the right of the word navigator, there is a line saying FIT FILL 1:1 1:3 then an up/down arrow. Click on 1:3 and your zoom click in the main image gives 1:3. Use the up or down arrow and select another zoom. Click on the main image and it zooms by the selected amount. Hope this helps for Lr3!
Photo Taker for ~30 years.
Books: The Art of Photography- Barnbaum, Photographically Speaking- duChemin.
@Clifford Rourke on Twitter, Clifford Rourke on Google Plus
How 2 the signature below?
In your profile signature, click on BBCode ( linked under options ) and read up!
___________________
Visit MrCliff on Flickr
___________________
PostPosted: Mon Jun 04, 2012 8:43 pm
Cool, now I understand, thanks
Ok, I found it in Navigator but could not find what you mean Loupe view. What I was looking for was while in Develop. The Navigator works but I was hoping for something easier because I generally have the Navigator minimized while in Develop. But hey, it gets me where I need :D Thanks to all of you!
Mike "The Squirrel"
PostPosted: Mon Jun 04, 2012 9:54 pm
While in the Develop module (and Loupe view) with Panels hidden:
Note the down arrow on the right end of the toolbar which pops up the menu as shown; when Zoom is checked on the popup menu, the slider shows up on the left (circled).
PostPosted: Mon Jun 04, 2012 10:11 pm
OK I got it :oops: I had to go up to view menu and start mesing around and hit View Toolbar then I was able to hit the down arow on right as you said. Thanks!!
Mike "The Squirrel"
PostPosted: Mon Jun 04, 2012 10:15 pm
Glad you got it figured out. I guess it's true that a pic is worth a thousand words.
